Out on the lake today, did alot of idling. Noticed every now and then it would sound like a cylinder would stop firing, decrease in the rpms, then it would pick back up and fire again. Intermittent spark?
That is what I thought it was.
Back to the house after a great morning. Take the boat up to the shop.
Hook up timing light. All four cylinders are firing.
Pull the plugs do a compression check, all cylinders are in spec and within tolreance on variance.
Re-install plugs start engine up, starts easy idles good. Grab the insulated pliears and stat pulling spark plug wires.
#1 makes adifference, decreases rpm. re-install increases rpm.
#3- same as #1
#2- same as #1 and #3
pull #4, no diference in rpm, installed or uninstalled spark plug wires make no difference.
switched spark plug wires with #2 and traded wires on the power pack/amplifier assy. Now #2 coil will fire #4 cyl and vice versa.
Pull #2 spark plug wire no difference, pull #4 wire decreases RPM
So it is not electronic problems???
Only thing left is fuel, I guess. Carbs have been rebuilt, twice
Could it be a bad reed valve? not getting enough fuel to the bottom cylinder?
This is the same engine I posted about a few weeks back that had a miss and was sputterin misting on the bottom carb port side. I replaced a intermittent coil then and thought I fixed the problem.
I have never seen a cylinder have spark and pull the plug wire while running and it does not make a difference in idle speed, has to be fuel but where am I losing the fuel at idle speed?
thanks for the replies.
#3- same as #1
