Re: water temp gauge
To CharlestonMako:
The 160 Idle and 140 running temperature ranges are exactly the ranges that my 1988 140 runs in. My system should be the same as yours.
I would expect that the Starboard side would be slightly different, but I don't have a switch to check it - maybe someday....
As soon as the engine is started, it goes into QuikStart which advances the throttle. When the temperature reaches 96 degrees, Quikstart kicks out and you feel it. Shortly after that the temperature of the water reaching the thermostats from inside the engine reaches 140+/- degrees and the thermostats begin to open and close. From that point on, the temperature on the gauge should stay somewhere between 120 and 180 all of the time. I don't see a problem with a wider range of temperature on the gauge, but I also don't see the necessity for it.
The main thing for me is knowing that I not in the overheat danger area, and knowing that my thermostats are not stuck open, causing the engine to run cold. Big bore loopers don't like running cold.
In other words I get used to where the gauges are reading and would be aware of a change, just like I read the gauges in my car.
