Hi guys...  Yet another problem with my motor..
Well heres whats happening...
I had to replace the stator and a coil as they died... Then My lower carb basicaly would fill but wouldnt allow gas out.. I solved that as the gasket was covering an oriface. So finally I got to run it on muffs.
Well heres my new problem...... prior to all this when running on muffs i did notice dark oil coming out of the center hub exhaust. I knew that this is normal. However, now the oil is more milky white not sooty.. I have chcked an i have both cylinders firing.. I do not have as much white smoke coming out of the prop now. But its stil there I am using penziol sythetic oil.. just wondering if i have a new problem.. I did notice at idle that some gas comes out the front of the lower card. its done tis since i have had it and i reult the carbs checked reed plates and never been able to cure it... oever whe on the water runinng above idle no gas comes out the carb.
I have checked the lower unit drained and filled with the correct type c and there was no water and the oil level didnt change.
Thaks for your help
Thaks for your help
