Re: Starting Problems
			After CHARGING batteries for 5- 10 minutes it cranks and runs fine.
hello,
i cant tell u what is wrong, but i can tell u what i would do... next... based on ur comment here.
if it were my boat... i would disct the grounds to my batteries. before i tried that i would do test #1: as currently configured, 10-14 days later from last start, i would read the batt's condition via a voltmeter.
 gosh, i like mine. then i would:
do test #2. for that i would disct batts after last run. then read the batts condition with vm before i put terminals back on and before any charging etc. do they read the same? as in test #1.
then with this info, i would put terminals on and before start, i would read batts condition. and if u have to charge for a few mins i would then read again. and note volts.
this info may help u determine what is going on. i would want to know why 2 HD high amp batts dont start my engines... but with a charge for 10 mins or so it will. 10 mins should not provide that much additional charge to batts.
additionally, i would want to know if there is any draw thru system with terminals on.
u say per above, so do u crank with charger on or with it disc?
well, that is where i would hunt. good luck.
regards
lakester
