Ok, here we go. I consider myself a novice boating enthusiast although I have owned several boats (I know how to use them properly, just not all the technical stuff).
I have a 15ft 6in bass boat with a 1988 Johnson seahorse 70hp. I know that the prop is not original because I have the original off as a spare. Nor did I replace the prop, it was on there when I got the boat.
What am I looking for? A good, cheap (preferable aluminum) new prop, but I have no idea about things like pitch, ventilation and the such. I have done some reading on the internet but I am still confused as to which one is right for me.
I use the boat for fishing in local bass tournaments. I need a decent hole shot but I want to maximize top end. Which one do I get?
Also worth mentioning: With the prop I have now, when starting off it takes a while to get on plane. But just before it does, as the bow is lowering, engine rpm's skyrocket and it seems the prop is almost out of the water. Once the bow settles, off I go like a rocket. Is there a problem there?
