Stupid tool tricks
jtexas
Torque wrench:
Specs said 28 to 30 ft lbs. Suspected I passed 30lbs but having no formal training, I stuck with it until it got looser instead of tighter. I was going to say it was cause the new torque wrench is way more subtler when it breaks over, but I'm tired of covering for stupid tools.
Electric drill:
Ok, it's true that the seal carrier holes are right next to the water pump housing holes and the same size, but why the stupid drill drilled out the wrong hole is beyond me. You think the drill cares about the price of gas and the time it takes going back to the hardware store for another hellicoil? I bet those fancy cordless "smart drills" never make mistakes like that.
But don't worry, I'm way to0 smart to call a tool "stupid" to its face........
SgtMaj
Re: Stupid tool tricks
As you get older they start hiding from you. In your hand.
Ain't that the truth! Half the time I spend working on my boat I spend looking for the tool that I just had in my hand a second ago.
KewlBird
Torque wrench:
quote]
I read your "other";) post and at one point in time that will happen to most of us. How do you know it's tight enough? You stop right before it starts getting loose again :D.
puddle jumper
Torque wrench:
Is that not a quarter turn before mush. I think that's the correct terminology;)
kenmyfam
So it's not just me then !!!!
larky
when i comes to torque wrenches i use the beam style. its probably not what the pros use but i feel i can trust it more. My dad had one of the clicking style when i was a kid and we put it at the lowest setting, locked it in a vise, and we still couldn't get it to click. the thing was brand new. we must have been doing something wrong.
Another childhood story about losing wrenches, when my father was working on the car, my brother and I decided that it was a good time to work on our bicycles. we would grab a tool that dad had laying around under the hood and use it ourselves. it would take him 20mins to figure out where it went. The funny thing was that we wouldn't do it intentionally, we were just to young to think twice about it.
bandit86
Banned
I had one, broke it out of the packaging to do a headgasket. tightened all the bolts down, first 70 then 90 then the first bolt at 110 the extension broke. what a horrible feeling I had, thought it was the bolt stripped.
I put the torque wrench in the ice, went up ny 5 pound increments, it stopped clicking at 105
beerfilter
Figured sombody would post this sooner or later , so ... :D
Automobile Tool Definitions
Hammer:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit.
Mechanic's Knife:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing convertible tops or tonneau covers.
Electric Hand Drill:
Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
Hacksaw:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Aviation Metal Snips:
See Hacksaw.
Vise-Grips:
Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
Oxyacetelene Torch:
Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer (What wife would think to look in there?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell.
Zippo Lighter:
See oxyacetelene torch.
Whitworth Sockets:
Once used for working on older British cars and motorcycles, they are now used mainly for hiding six-month old Salems from the sort of person who would throw them away for no good reason.
Drill Press:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Rolling Stones poster over the bench grinder.
Wire Wheel:
Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Django Reinhardt".
Hydraulic Floor Jack:
Used for lowering a Mustang to the ground after you have installed a set of Ford Motorsports lowered road springs, trapping the jack handle firmly under the front air dam.
Eight-Foot Long Douglas Fir 2X4:
Used for levering a car upward off a hydraulic jack.
Tweezers:
A tool for removing wood splinters.
Phone:
Tool for calling your neighbor Chris to see if he has another hydraulic floor jack.
Snap-On Gasket Scraper:
Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z Out Bolt and Stud Extractor:
A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
Timing Light:
A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
Two-Ton Hydraulic Engine Hoist:
A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect.
Craftsman 1/2 x 16-inch Screwdriver:
A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
Battery Electrolyte Tester:
A handy tool for transferring sulfuric acid from car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
Trouble Light:
The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
Phillips Screwdriver:
Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
Air Compressor:
A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off.
jtexas
This one in particular spoke to me, after my socket wrench pulled a stunt it regretted until the end of its miserable life.
You know the screws holding the lower unit to the midsection? The ones directly above the anti-ventilation plate? You have to use a box-end wrench on 'em until they get far enough in that the socket & wrench fits in there?
Ok, so I get the wrench/socket on the screw head and start ratcheting, but for some reason, the stupid wrench backed the screw out instead of screwing it in.
Backed it out until its progress was stopped by the A/V plate. Wedged itself in there pretty good. So good in fact that I couldn't operate the direction-changing-clicker-thingy. Managed to manhandle it with needle-nose, breaking nothing except that smart-@55 wrench.
[note to sgt maj and kenmyfam: I find that I can often coax hiding tools back out into plain sight by walking away from the work area and waiting a few minutes. Usually (not always) quicker than searching for 'em.]
oops!
TOOLS HAVE LEGS !!!!!!
i did a 12 corona study...late one night......
was on the inside of my hull working....the tool i had just used.....got up and walked to the floor just out of reach.....
i had to get out of the boat and get it....
then while working on the outside of my hull..the tool jumped to the inside.....
musta done that 60 or 70 times :eek:
i think tool manufacturers are in cahoots with the paper coverall dealers....you rip one every time you get in or out of the hull!!!!!
its a conspericy man.....really...!!!!
beer filter.......that was great
TriadSteeler
15 minutes rummaging thru the roller cabinet, 4 tool boxes, 4 drawers, the boat bilge, the pile of crap on my workbench, & the garage floor only to find that the socket I was looking for was already on the ratchet. In my hand.
newbie4life
My BIL worked on my brakes on my old truck one day, and finally got 'em working the way they're supposed to... something about a proportioning valve or something.
Well, I took the truck in later for something else... I don't remember what, exactly. But I went to the shop to pay the bill, and pick up the truck.
"Here's the keys, your paperwork, and the two vice grips that were stuck to the proportioning valve."
I still mention that to him every other time I see him, just to get under his skin. I joke that I'd like to have him do some work on my truck, and I see Farm and Fleet's got a sale on Vice Grips..........
Captain Paul
When I was a wee mate and Dad was working on the car, boat or whatever, and he would ask me to come over and hold the trouble light. As kids do, I would get bored and always end up causing my Dad temporary blindness by blasting the light 4 inches from his cornea. Oh how he would chew me out. I love my Dad.
Sig_Mech
Hey Captain Paul, I can really sympathize with you. I did the exact same thing with my dad and it would really tick him off to no end. I just couldn't understand why he kept on asking me to hold the light all the time. Jeez, you think he would learn.
He also had a bad habit of laying his pack of smokes on the garage floor right where he was working. He would call me over to hold the light and somehow my feet always found that pack of cigs. I can still picture him trying to light a broken cigarette while blinded and yelling at me as I ran away.
Ahhhhh, good times.
D
DJ
Guest
-How many have lost your marking pencil? Only to find it, after you went in the house (spent a 1/2 hour looking for another sharp pencil) to find the old one when it went from behind your ear to fall into the back of your shirt collar?:redface:
-I found my 9/16" Craftsman end wrench, after a two week disappearing act, when it went through the aluminum deck (took out the blade too) of my Lawn Boy.:eek::mad: It seems my boys thought it was a pretty heavy duty tent stake. The tool was fine. Just a little "character" nick.
HyperFox
As I am a self proclaimed 1/2 redneck (Sophisticated redneck) I have my own tool descriptions I thought Id add:
Thickness Plainer - Effective 2x4 launching device. Projectiles automatically lock on to any glass or thin metal target.
Ruler - Alternate Thickness plainer ammo.
Jointer - Another 2x4 artillery peice.
Oxy-Acetylene torches or propane torches. - Excellent tool for inadvertently lighting the bolt and car or boat on fire you just soaked with spray lube.
Adjustable wrench - Should be sold with band aids. Great for testing out your knuckles skin depth.
Stud finder - Aint figured it out yet. It still cant tell the difference when the horses are all in the same place!
Socket set - Bolt rounders. 13mm and 1/2 will disapear within 30 mins of purchase.
Torque wrench - Tool made by people who own machine shops, I swear. And its always the LAST head bolt that snaps off!
Potato Cannon - Keeps the kids outta yer hair. And keeps that neighbour away after the 2x4 goes through his picture window.
Old gas can - Nobody knows how old the gas is. Or wants to try it or dump it.
Junk drawer - Contains every nut and bolt known to man. Except for the one you need.
Toilet paper - Improvised bandaid if used with gun tape.
Gun tape - military variant of duct tape. Same, but olive drab. Used for taping kids to wall, hiding mistakes, repairing small jobs, or big ones.
Rusty swiss army knife - kept as a momento.
Small tool box - Used when the big one cant come with you. When at the site, the tools will be mixed up and will magically replace themselves with the ones you don't need to do the job.
Sawzall - Nuff said....
wkearney99
Heh, back in high school, during the 'gear head' phase, we used to call that "torque it until it breaks, then back off a half turn". Ruin a Saturday night cruise with the ladies by breaking a cylinder head bolt on a Friday night and you learn the value of a torque wrench RIGHT QUICK.
