Re: 82-84 140 hp carbs needed
There is a set on ebay: 250223467463. Note: These don't have choke plates, and don't appear to be drilled for the fuel primer inlets on the top of the carb. I believe the engine that originally had these carbs had the fuel primer solenoid plumbed direct to inlets drilled into the 4 crankcase intake covers, on the sides of the block.
