Broken Lower unit big deal?
TwitchSD
I am thinking about purchasing this outboard but as you can see in the pic the lower fin is chipped just behind the prop I haven't had experience with this. Would this affect the outboard in a noticeable way at all? Thanks.
tashasdaddy
Re: Broken Lower unit big deal?
there are million running today with skeg like that. if it bothers you, you can have a skeg guard put on it. that zinc anode, needs replacing.
kenmyfam
Buddy of mine has run his merc like that for the last 5 years. No problems.
TwitchSD
What is a zinc anode? I am new to all this young and all, 24, just got my first boat a couple of weeks ago.
D
DJ
Guest
The square shaped piece above the cavitation plate. It's the part that looks corroded. It's supposed to be corroded. It is a "self sacrificing" anode.
I would be concerned about general maintenance, on that engine. It looks like it's seen some hard use.
I would check:
1. Lower unit lube.
2. Propshaft straightness.
I'm sure it needs a water pump.
