XR4 Bearing Carrier
DOCD9501
I would like to know how to get the carrier out. I have the crown ring off but I am not sure how to remove the carrier if anyone could help. I am trying to change all the seals.
Faztbullet
Re: XR4 Bearing Carrier
Remove the carrier nut (crown ring??) and either use a puller or slide hammer to ease it out. There will be a small square key at the 6 o'clock postion so dont lose it. Be careful as if the propshaft comes out there will be a follower(pointy piece) and 3 small s/s ball bearings that will fall into housing or floor. Go slow and everything should be allright..;)
DOCD9501
Thanks thats is what I thought but wanted to be sure
