Buy Muffler Bearings Online!
Don S
Re: Buy Muffler Bearings Online!
They have changed a lot from the older style. Used to be only one, not two.
Haut Medoc
Are you installing new ones in this pic or are you just inspecting them?......:confused:
They look like new to me.....:D:D:D
oops!
HOLY SMOKES...ITS AN IRON-GRAPHITE COMPOSITE..!!!!
i wonder if it adds any extra horse power?????
as P.T. barnum said................
D
DJ
Guest
To get the best service life out of them, it's best that the kinibblin pins and whatchagaskets be replaced too.
kenmyfam
Do not forget to hold the replacements in place with NEW gangle pins.
Bigprairie1
...they have a lot of good stuff. I recently bought a bindeldorfer housing from them.....works great, despite the smell.
BP
kenmyfam
BP
Did you not get the version with the Febreeze injector ???
muskyone
Master Chief Petty Officer
i just orderd the flux compaceter i'll let ya know how it works
cbavier
Ha! Ha! :D Where did the muffler come out of? The bottom of Lake Superior. No wonder the muffler bearings were shot!!!:D:D:D
Guess I need to check mine. Since you reminded me. I'll put that on my Spring to do list. :D It's not long enough yet anyway. ;)
Chuck
ezmobee
I need to place an order, my supply of headlight fluid is about out.
thurps
I found the product reviews insightful.
joed
Porcupine seat covers are on sale this month. 75% OFF.
pduquette
Ensign
"aww Comon guys- you forgot to remind him of the lube oil ; ya'all slipping!!!!
BTW it calls for KY super warming lube due to the high heat buildup!!:D
angus63
I believe those are also a direct replacement for the relative bearings on my vessel!!!!!
BRG25
Personally I found the Porcupine Seat Covers intriguing.
TAV MAN
I can't fine the opening on my muffler, or do I have to pull it off to get at it.
Kenneth Brown
Glad to see the mods in good humor over KaleAuto this time around. I posted this about a year ago and it got deleted because they sold stuff. Nobody ever checked to see what they thought was being sold.
wavrider
I use prop wash to clean my muffler, helps to locate the bearing.
SuperNova
If you really want your muffler bearing to last you have to do two things.
1- Make sure it is the correct rotation, i.e. left-hand or right-hand and
2. Make sure to pack it with spermicidal lubricant for maximum rust resistance.
