I'm having a problem getting my motor to shift out of neutral into reverse or forward at all. It takes quite a few tries to start the engine from cold, but it runs and seems to idle fine once running -sputters occasionally. But as soon as I try to shift it into reverse, you can hear it trying but it just dies every time.
Bought this in November and it hasn't been tagged since 2004 until now. I've read and found some answers that it may be a "link and sync" problem or a "timing advance" problem. I don't really know what this means or how to fix thies eproblems... if this would be the problem with my motor, could someone give me some instructions?
I'm 19 - not a genius at motors, but I think I've figured out where the idle screw it - about halfway up on this arm thing on the engine- has a rubber cap that rests against a metal plate. It is already screwed in all the way though. Should I put something against the plate to make the idle speed higher? Spark plugs seem to work fine -that is, they give a spark...
One last thing - there is a knob I haven't messed with on the control box either on the front of it or underneath. Looks like a screw cap or something that twists... does this do anything for me? I haven't messed with it yet. Maybe it's an idle adjustment from the control box? Thanks for any expert advice!
Jon
Jon
