stringer fitting
peacekeeper6
if someone could take a look at this stringer fitting and tell me if this is what its supposed to look like? there is a gap in the front and i heard that the stringer isnt even supposed to touch the boat, you were supposed to fill it with resin or some sort of adhesive.
tashasdaddy
Re: stringer fitting
close enough for me. this is controversial, but i like to use a bed of PL Construction 100 % poly adhesive. then glass them in..
lundnisswa
T.D.
Interesting; would the 3M 5200 work in your opinion to fill up those gaps to make a bed for the stringer to lay in?
I am currently cutting to fit stringers also, have alot of prep work to do still but I have been contemplating the best method to stick these to the floor.
Epoxy mixed wood flour?
Epoxy mixed with milled fibers?
Comibination of the two?
And now Poly Adhesive?
I guess I will go with one of those because I have it all on hand now, how about if I do one each way, since I have four stringers.
Lund
tashasdaddy
since you have the stuff to mix, use it. 5200 gets too hard.
jcsercsa
Hay wait a min, guys !!! arent you sposed to grind all that old glass out frist ??? Sorry snakethis69 but that is what i was told ???? John
peacekeeper6
i thought that two nubs around the stringers was supposed to stay to creat a "bed" to fill for the stringer?
rockyrude
Tashasdaddy, I like to consider you the expert on the rebuilding, has the PL adhesive gotten so good we can forget peanut butter? Makes life a lot easier.
