I'm in desperate need of help here.  I have a Johnson 115 1977.  My boat has always had starting problems, but seemed to run okay after warming up a little.  However, it would conk out on me in the middle of the lake from time to time (once out of every three trips) and have a difficult time starting back up again. Also, at high speeds it would suddenly sputter almost as if a wire was grounding out or I was losing a cylinder or two.  It always seemed to run much better during the warm months.
My uncle sold me the boat about three years ago, but he hadn't started it up for about eight years.
As far as the maintenance goes, I've rebuilt the carbs, put in new fuel lines, rebuilt the fuel pump, replaced fuel connectors, and cleaned out the tank. I can tell that I'm getting fuel to the carbs, because it was running after I performed this maintenance. But, it was still having the same problems as before.
One day I was on the lake and it was running all day without a major problem although it would stumble whenever I opened up the throttle and wouldn't get up to speed. I took it home and hooked up a fish finder to it, running it off the battery. The system is a 6 amp and is supposed to handle that one extra unit without any problem.
The next day I could not get the engine to kick over at all. I then used a multimeter and spark tester to test all the ignition equipment. My stator checked out fine, but my timer base displayed a low volt reading. I decided to change out those parts along with my rectifier and power pack since it had been sitting for so long. I used CDI parts. I was getting very little spark on my 1 cylinder before changing the parts out and no spark on the other 3 cylinders. Prior to installation, the I parts I ordered checked out fine using an ohmmeter. The plugs are new.
Still, the engine will turn over just fine, but will just not run. I'm not getting any spark at any of the cylinders now. A couple of points: I took the boat to a local boat mechanic about 2 years ago to try an solve the gremlin problem, and he said that the wrong spark plugs were installed in it so he put some others in it. It seemed to run okay for a while but it started backfiring a lot which it didn't do before. I ran it that way for a good 3 or 4 months, but it was going through plugs too fast. Turns out that the mechanic installed Champion QL77JC4 instead of the L77JC4. The Champion plug website specifically says not to install a resistor (Q) plug in place of a nonresistor plug otherwise it can damage the engine.
Also, when I removed the rectifier I noticed that the insulation on the positive wire had worn away and if I moved the wire it would spark once it hit metal. Could this have shorted out my other ignition parts or caused other damage to them?
The only two things left are to change all four ignition coils out and/or check the entire wiring system to make sure I don't have any loose grounds. Have any of you had these types of engine troubles, and did changing out the ignition coils have any effect. I've even heard that Johnson did a recall on those coils back in the day. Any help would be much appreciated.
EM
EM
