shrink wrap
torcano
It is commom practice in the northeast to shrink wrap boats for winter storage. What is the advange of this over a tarp? It seems as if the shrink wrap would tend retain left over mositure in the cabin that could be avoided with a more breathable tarp or mooring cover. Is it worth the expense to shrink wrap?
Thanks,
RK
eastern27
Re: shrink wrap
Thanks,
RK
I don't think so. If you build a good pvc support frame to handle the snow, tarps work fine. You do have to get out there a clear snow when it's the wet stuff but it's not a big deal. I have a 22ft. CC and a 27ft. Downeast Style in the yard right now under tarps. A few years back the local boat yard quoted something like $300 to shrink the 22 footer. I bought a 30 X 40 heavy duty trap for the 27 and have got 2 winters out if it, $65. You do have to keep your eye on things, water in the bilge will wreck your boat in the winter. If you can't keep your eye on things then shrink is proboly the beast bet. They can install vents to keep the the inside dry.
Silvertip
Re: shrink wrap
There is not a lot of humidity in the air once temperatures get below 32 degrees. Drive by a marina here in the upper midwest and all you see is a sea of white. Shrink wrap is the universal winter storage solution. It is very durable, sheds snow and ice well and doesn't create pools like a slipping tarp can. Yes -- they are vented.
maxturbo
Re: shrink wrap
If your looking to save some money go with the tarp. But only if you can keep an eye on it. Cause like mine when it snows or rains you do have to wipe it off. And also you need to watch out for mice or squirrels or anything that can find its way in and make a home for the winter.
Scaaty
Re: shrink wrap
My take shrink wrap might have a place in life..(jeezz, why NOW its the magic ..($$$)...thing?
50 years boats...parked Midwest and Pacific Northwest...one SOLID winter, one 6 months wet outside.
NEVER did anything but a full tarp over...WD the crap out of it where needed for corrosion, couple flexible 4 inch tubes (PVC or Drain..few bucks Home Depot)... out the back for air transfer...
The "wrap"..?...good for transport down the highway..
Thats it, and thats all.
50 years parking boats, and aint buying the "wrap" thing one darn bit...
Silvertip
Re: shrink wrap
Are you saying you would pass on a Corvette or Viper because a Model T was good enough to get you where you wanted to go? :) Cheap can work but there are other options -- usually better as well. It's all a matter of circumstances and what you want and are willing to pay for. I think that's called supply and demand. If there was no demand there would be no shrink wrap (except in electronics).
tashasdaddy
Re: shrink wrap
i think it has it's benefits, in the cold areas, where the boat is stored 6 months of the year, down here, tarp. can be off in 5 minutes, and the boats ready to go.
Cruiserman
Re: shrink wrap
Thanks,
RK
I keep both my boats on cape cod in the winter. There is usually not that much snow. I tarp every year and put supports inside the boat.. it works very well.. There is no real rocket science to any of this. The tarp is not air tight, so venting takes place. There are plenty of people out there to serve the boating industry and perform any function that you want ... for a fee. If you dont have the time, then pay someone for it.. If you are like me, I like to do whatever I can for my own crafts, and I make as much time as possible for a hobby that I love...I do, however, pay a professional to winterize the powers.. I like the professional scrutany for any potential problems... and, hey, my marina guys have to make a buck here and there...
oops!
Re: shrink wrap
in victoria canada in the early 90's shrink wrap was just coming in.....i knew the guy that had the product line......
he sold lots.....then spring came ...the shrinked boats were full of mold...i dont know of they did it wrong or what.....but thats what happened
donnymac
Re: shrink wrap
Welcome to the wet coast!
Black Snow Slide
Re: shrink wrap
I tarp as well because a tarp also covers sides of the boat, over sides of trailer offering uv protction and keeping breaks and cuppler out of the winter weather. I can put the entire tarp on in 12 minutes and off in about 10. Do that with shrink wrap.
arboldt
Re: shrink wrap
I keep mine in the garage at the cottage over the 8 months of winter, with all hatches etc propped open for ventilation, so it's all uncovered. Then 3 or 4 packets of D-Con around the insider perimeter of the garage, and we've never had a problem.
And the neighbor has stored his 'toon in the other half of the garage for over 20 years, with no problem.
stripernut
Re: shrink wrap
I used to use a tarp to cover my boat but found they wouldnt last more than about 6 months. I happen to work where we make the shrink film...So its a no brainer for me to use it instead of buying a tarp every 6 months. I make a new cover for my boat about every 6 to 8 months. If done correctly it will be vented and I can remove it in about 5 minutes and put back on in about 10 minutes....I like it a lot better than a tarp as it sheds water better than a tarp will and if it tears it can be replaced without ever having to leave the yard. Then again if it was going to cost me 300 bucks 2 times a year...I think I would consider building a pole building in the back yard..
orion25
Re: shrink wrap
If you are worried about moisture then get a couple of buckets of Damp Rid. My boat spends the winter in the back yard under a $100 universal canvas cover. I put a large bucket in the helm area and a small bucket in the bilge. Mo mildew problems when I took the cover off last weekend (Cover had been on since November and temps had ranged from 6 degrees F to 65 degrees F.
