And so the saga continues......... :-( .... (Pics)
Theoutdoorsman
While attempting to remove the core plugs from my carb, I accidentally went too deep with my punch and punched a hole through the base. Everything still move freely though. Is this carb trash now? If used, what effects will this have or should I expect to see from this? Geeez, I finally get my long awaited trim cylinder leaks repaired and now this!!! It never fails. If it weren't for bad luck, I'd have NO luck at all!!!.............. :-(
P.S....... Please take a look at my fuel pump related thread from earlier today, if time permits. I could really use some help on the re-assembly. Thanks guys............. ALAN
samo_ott
Re: And so the saga continues......... :-( .... (Pics)
You punched that big hole in the middle? Uh, it looks toast to me. There's no way it will work properly, hate to tell you. Others are sure to comment also. Too bad.
Theoutdoorsman
yeah......I punched that big hole in the middle. I figured the idle would be the only affected area. Thought maybe it might run rich is all. Surely I'm not the only one to have done this....... :-( ........ What gives?
samo_ott
You're probably not the only one to do it, but you might be the first to fess up to it!!! :)
Maybe you could try to put a tiny bit of JB weld in there on the end of a pencil or something like that to seal it? I've never tried though. Maybe others have a better idea.
jay_merrill
I would say to forget the attempts to repair it ... eventually you are going to replace this carb anyway. Chalk it up to a lesson learned, buy another carb and move on.
57whitehouse
I would put a spot of JB weld on it and run it til it doesn't run anymore.
MarkV_Deep6
I feel your pain!!!!
I vote to replace....it will always be an issue in the back of your mind when out there trying to enjoy a day on the water....
Theoutdoorsman
It will eventually be replaced no doubt. But, can I use it temporarily until a replacement can be located and purchased? I was Just wandering what to expect. Surely I'm not the only one here to have done this and tried running with it. If so, I guess I'll be the first to try it and post the results of the outcome. I don't foresee any detrimental impact of running a carb too rich at idle. Maybe a fouled plug or two would be the worst case cenario.........right?
BF
if it were me, and I were gonna run it in the meantime, I'd clean it with acetone, then plug the new hole with something. Is JB weld impervious to fuel? I know there is some stuff in a tube called "seals all" that I've heard people use to seal punctured gas tanks. That's probably what I'd use (?) or depending on the size of the hole, you could either screw in a small sheet metal screw, or tap it and use a small machine screw. If I were doing either, I'd add either some "seals all" or locktite to the threads.
that's my $.02... good luck
samo_ott
I like the screw idea as if the jb weld got sucked into the reeds or worse, the pistons, that'd be real bad and you could toast your engine. The screw would never go through.
Faztbullet
What size carb is that ?? 1-5/16 or 1-3/8. I got a lot of these laying in a box if you need one.
Theoutdoorsman
This is the route I will most likely persue. I'm thinking of a very small stainless steel sheet metal screw, about the size of one that fits the ear piece on your sunglasses, perhaps with a small lock washer to add a little security to the deal and not use any type of locktite. I don't think it would do any good as the fuel would eat it up. I will file away the tag end of the screw that protrudes through the carb body so as to not interfere with the movement of the butterfly. I'll then proceed with the carb cleaning and rebuild. Wish me luck. I can sure as h**l use it right now.....LOL
Faztbullet
Why go thru all this?? e me your throttle bore size and I will ship you a body if I got it !! You pay shipping only body is free!!! I am just across da border so cant be much ...
HighTrim
Awfully nice, I would take him up on that offer.
Theoutdoorsman
I'll post a photo of the carb body along with the casting number. Let me know if you can come up with one. If you can, at least let me buy you a case of beer for your generosity. I won't take NO for an answer. Your a good man Faztbullet!!! ....... :)
Here you go!!!!
Faztbullet
Dug thru the boxes ,found ya a carb complete. it is the top but with little mods will work on bottom if needed. Pm me your address and will ship to ya!!!:D
samo_ott
Wow. You can't beat the good folks on this forum!
Benny1963
cant beat that deal .
good luck bennyb ,
jay_merrill
I think Faztbullet gets the "iboater of the month" award. I'm also glad to see this happening because I believe that the JB Weld option was a bad one for the reasons that Samo Ott mentioned. JB is good stuff for some things but it does break up after awhile and having little bits of epoxy floating around in your carb would not be a good thing!
BTW, Faztbullet, if you happen to have a spare Yamaha 2-stroke 90hp in running condition hanging around, I'd be glad to send you my address too! :D
