pine island fred
- Dec 20, 2002
- 1,144
Just broke the trim position switch on an 03 ox66, 200 hp. Switch will have to be replaced. Expected to follow the 2 wires from the position switch up to the dry side under the cowl and find some disconnect plugs. Only thing I can see is the wires going into a rubber tubeing, into the cowl area and continuing out the engine with the rest of the wires and hoses. Got to be some disconnect somewhere on the engine. Are the wires terminated right at the position switch or are there some disconnect plugs inside the protective rubber tubing? thanks FRED
