1996 115 Evirude Issue
Survone
Just aquired a decent 19' Wellcraft with a 1996 Evirude 115 outboard. Now when I finish a cold start upon starting the motor it will not stay at idle it keeps cutting out i checked the bulb it feels fine. Now the other issue I have is a motor wont engange in gear the throttle cable is very stiff and doesnt not appear to go out of Neutral...I am stuck...HELP!!!!!!!!!!!!
rndn
Re: 1996 115 Evirude Issue
Welcome to the forum Survone!!:):)
When is the last time the 96 Rude 115 had a tuneup? How about a decarb? How about a carburator cleaning? I know you just acquired it so you may want to give it a full tune up before you start digging deaper. Is it fresh gas in it?
The other motor you mentioned about a sticking cable, what year and HP?
tashasdaddy
Welcome to iboats, when you start do you bump your key in several times until the motor settles down. there is a release lever on the control handle, that locks it in neutral. you must squeeze it to shift into gear.
