Dshow
- Jan 1, 2007
- 313
It's time to summerize the boat, YEA! I started it on the muffs and noticed most of the water was coming out the port side, below the outdrive and the thru-hull exhaust. The starboard side below the outdrive was coming out, but not as much and there was none come out the starboard thru-hull exhaust. I got in the boat and felt the port exhaust riser and it was cold (74F) but the starboard side was hot (~130F)... The engine ran fine and came up to temp and stabilzed at ~160F. Am I being paranoid or should investigate a blockage and if so, where should I start?
Thanks for your help!
