Evinrude 90 v4. I just changed the water pump and put the lower end back in. the problem is that it seems to be in drive when it should be in neutral and its in neutral when it should be in reverse. when i put the shift rod back on, it connects from the starboard side via a small pin that is moved in and out via the shift linkage. so if the throttle is in the neutral position, the shift rod would have to be in neutral to line up for the pin to go through, it seems that you cant screw it up but apparantly i did.
any help would be great, here is a pic from the starboard side.
