BlueStreak
- Apr 7, 2008
- 3
Awesome forum here. I've been reading quite a bit since I discovered my unwinterized engine had 2 popped core plugs and a cracked intake manifold. I'm the original owner of this 1994 VP 5.0FL PDMA (Ford 302 V8) with the SX-S 1.66 drive. 466 hours in fresh water only.
The engine started normally--for the first post-winter startup--and I ran it for 2-3 mins before I noticed the rear plug on each side of the engine was out. Not knowing better, I put the core plugs back in and restarted, only to discover a crack in the intake manifold where it connects to the thermostat housing. The engine ran normally for the 20-30 seconds before I shut her down. (Upon pressurization, a finger-sized stream of water shot out of the crack in the intake manifold.)
I removed the intake manifold and can't find any cracks in the block valley nor on the engine block or head exteriors. No apparent water in the cylinder air intake ports. The one spark plug I pulled looked normal, no water. The engine oil looks clean and clear, not milky.
Initially, I figured I'd get another intake manifold and restart the engine. After reading some threads today, I'm thinking I need to at least pressure test (if not replace) the exhaust manifolds and risers before restarting the engine. In addition, I plan to do a cylinder compression check.
What's the likelihood that the block (or heads) cracked between cylinders or some other place not visible? Since the water is circulated thru the engine block then the heads before it gets to the intake manifold, I'm thinking any cracks there would have shown themselves? (Wishful thinking?)
Are there other things I should check before restarting the engine?
Thanks in advance for your comments and suggestions.
