HELP!!!! I have a 2004 Yamaha High Output Cruiser waverunner. I was in some really rough water in Orange Beach and the battery came loose. The ski went dead like I hit the kill switch a couple of times. I looked in it and found the battery loose. Battery died in the accident. I put in a new battery and I get no gauges or turnover. It turned over once right after I changed the battery then dead again. After trailering it home I tried it again and it cranked, then dead from then on. I checked the fuses...OK. Replaced the fuses. I have tested the starter relay, main/fuel relay, rectifier, and cables. Still no guages or turnover. Battery is good. It came out of my other running ski and shows 12v. I checked the main relay by testing it and swapping it with my FX140. (Same part number). I checked the rectifier by swapping it with th one out of my FX140 (same part number). Security system dead also. I have the shop manual and don't see anything else I can check. Any suggestions??? I'm at my wits end.
Sam
Sam
