Re: 1990 OMC 4.3L ESA Problem
			Actually it's ok for it to move going into gear, in the OMC factory manual it says quote" The ESA module will function when shifting both into and out of forward and reverse" end quote. Obviously it's more important for it to work coming out
I'll have to stand corrected on that one.  I guess I was referring to my 1987 King Cobra.   It did not actuate going to gear.  My service manual also indicated that it actuated when going into gear.
Mine shifted very easily and only actuated when coming out of gear....Maybe it should have actuated when going in.
On another note....The ESA does not
"KILL" the ignition.  (At least in 1987 it didn't)  According to the service manual the ESA "Pulses" the ignition and should cause the RPM to drop no lower than about 500rpm.
The whole point of pulsing the ignition is to cause torque (reduction) pulses so you can easily get the drive to shift out of gear by reducing torque on the clutch-dogs.. It's far more important coming out of gear than shifting into gear.
Bruce,   I LOVE that rotating prop avatar!!
Here's mine!!
