Re: 73 starcaft rotted floor ?'s
Hi Jweaver,
On mine, I found it easier to slide the rubrail out. Remove the end caps and it should slide out IF the aluminum part isn't smashed enough to pinch it anywhere. I had to wedge it out in a few spots on my 18-footer, but it wasn't too bad.
Second step is to drill out the rivits. That will remove the aluminum part of the rail.
Third is to remove the screws that hold the deck to the hull. T hey were STEEL on mine and many of the heads were rusted. Be prepared to drill some of them out.
Fourth step is to run some wedges between the deck lip and the hull lip. It is assembled shoe-box style with the deck overhanging the hull. There will probably be some very dried out sealant in the overhang that should free up easily with the wedges.
Removing all the fasteners & breaking the seal will loosen 90% of the deck from the hull.
The last 10% could be difficult as that is where the transom well is glassed to the transom core. Generous amounts of elbow grease, wedges, crowbars, shade-tree ingenuity will free it up. Lifting up on the bow helps, too. I found that by gently lifting the bow of the deck with a come-along and then prying on the transom stuff in various spots, it eventually broke free.
The open bow part shouldn't make things too difficult. I don't think the bow has a moulded in sole, so you should be able to just undo any seat backs & such that may be joining the deck to the floor/sides. Might want to make up some sort of supporting cross member to help spread the load in the center, as the two consoles will be relativly heavy hanging free from the sides.
I think that's it!
- Scott
