Re: Accessories turn off on battery 2
Shouldn't be any kind of fuse between batt 2 and the switch that would shut down everything. There would be AFTER the switch, but in that case nothing would work in either position. Since nothing works and you've tried a new switch, I would start at the #2 battery:
1) Is it charged? Just checking it with a voltmeter won't tell you anything, a totally dead battery can still show 12 volts.
2) You should be able to track down where the voltage stops with a voltmeter. Hook the negative on the voltmeter DIRECTLY to the battery so you don't have to worry about whether the negative cable is good or bad:
A) Is there 12 volts at the battery terminal? - If not, batt is dead.
B) Is there 12 volts at the INPUT on the switch? - If not, pos cable is bad.
C) Is there 12 volts at OUTPUT of switch? - If not, switch is bad.
If you get 12V at the output with the voltmeter negative lead hooked DIRECTLY to the battery, move the negative lead to the far end of the negative cable and see if you still have 12V. If not, then the negative batt cable is bad.
3) Another way is to swap the pos cables coming from batt 1 and batt 2 AT THE SWITCH. If pos 2 works now (it's using batt 1 now), something is wrong with your batt 2 cables (either pos or neg). Many times people use automotive battery cables when wiring up dual batteries because they are much cheaper than marine cables. For examle, a 2 foot #2 gauge Pep Boys auto cable is $7, a 2 foot #2 gauge marine cable is $55. Adds up to several hundred dollars difference when you need 3 or 4 cables to run the switch and 2nd battery. Problem is the auto cables are NOT tinned internally and the copper will corrode over time where you can't see it until you get no continuity. Swap the cables from the working side to the dead side one by one until the dead side starts working.
Good Luck!
