dingbat
- Nov 20, 2001
- 16,595
Re: Tie Down SS Disc Brakes, wore out after 400 mi
That is actually pretty good. No problem there1) I c clamped a straight edge to the leafspring so it was touching the rotor, spinning the rotors to the point at which it was not touching the straight edge to check if the rotor are warped and yes the are not perfectly straight, 1 is off by .011 and the other is off by .021.... hopefully somone knows what I am talking about. Is the a minimum reccommended measurment for this, These were not perfect when i put them on new, I assumed the were just "what I get" when you purchase the cheapest ss discs on the market and assummed they were within minimum requirements..
Do I need to replace them?![]()
3) The bleeders I can't get to break loose and I broke 1 an broke an easyout on it, I need to get 1 out intact so I can get the right tap
Any suggestions on breaking them loose without breaking them, heat,or what?
Thankyou for any help thanks![]()
Aluminum, brass and Stainless mixed in one assembly. Not good. I replaced my Tiedowns when I broke off a bleeder and tried to drill them out. The bleed seat is part of the caliper so unless you get lucky and don't damage the bleed seat when you try and drill them out it's time for new calipers, or as I did new Kodiaks brakes
