Expidia
- Aug 26, 2006
- 2,374
Does this make sense?
I have a front (the one closer to the winch) standard rubber 8 inch roller mounted in a plate.
I was thinking of getting a replacement 8 inch "self centering roller" for this front one and just reuse the plate and rod.
For the back one (stern) I wanted to mount a roller since it has this cheap flat piece of plastic that slides out of place anyway. With a roller I could use my transom saver that fits over a roller.
So I figured I'd get a 12 inch self centering roller (about $20), a 12 inch plate, rod with end caps (about $20).
I know Tashasdaddy from other threads uses two. But I can't seem to find "both" an 8 inch and a 12 inch in the same colors from various sources.
I just edge my trailer into the water until the bunk ends just go under so the back one should hit the keel fine.
The front one as self centering would be nice since many times I have to back boat off a little cause it's not centering on the front one on the first try.
Anyone know (to save on shipping) where I can buy an 8 and a 12 inch and the hardware from the same source and same colors?
Does it make sense to use "two" self centering rollers or is two a waste of money?
Thx
Thx
