my 1982 e4w that i have had since new just started black sooty spark plug fouling on the top cylinder with my first start up this year. idle and mid range speed fine then slight noticible shudder at fast speed. so far ,compressions equal at 70, & increased to 90 with squirt of oil into cylinder. fresh fuel,new plugs,replace fuel pump, replace both mags, points, condensers, clean and reclean carb. removed carbon from cylinder head ,pistons, exhuast. timing checked good, spark gap good. this carb has a fixed high speed jet and is clean as best asi can tell with out removing the shot from the top of the carb. I've not pulled the intake off to check the reed valves yet. Any thoughts on checking the reed valvesor any thing i' ve missed?
