FreeBeeTony
- May 15, 2002
- 3,991
Started the Vortec yesterday. put a hose in the water intake of the engine mounted sea water pump, cranked a few times and started right up.....by the time I looked over the transom to check for exhaust water........I realized I forgot to connect the ear muffs to the drive!!! I immediately shut the engine off.........then connected another hose to the ear muffs and restarted. The water flow coming out of the drive ( I can check it because the hose is cut) seemed to be fine. As I understand it the pump in the drive is only being used to cool the drive in my case. It only ran dry for maybe 10 sec.........was a new pump and probaby had some lube on the impeller.
Hope this isn't an omen.........
