I have a 1992 Mercury 200HP Offshore.  You can start it up cold and it will run all day long at whatever speed you desire.  Once it is warm and you cut it off for 10-15 minutes when you try and re-start it will run for about 15 sec and then cut off.  At this point the primer bulb is "limp".  I have noticed that when it starts to die I can pump the bulb and it will "perk" back up and continue to run.  It seems like once you cut the motor off and let it sit that the primer bulb will go limp and loose the gas that is in there.
My first thought was pickup tube but I replaced my tank last year and installed new pickup, hoses, and primer bulb. Could these be the symptoms of a fuel pump?
Any thoughts or experiences with similar problems would be appreciated.
