Re: sea king
If the cable isn't obviously broken where it attaches to the lever, it may have come loose in the lower unit, or broken down there. You can pull the lower unit and check...fix it or replace the cable. Then again, do you really need neutral? Direct drive outboards were all the rage up until the early 50's...just don't stand up in the stern when you're starting it or you could get an unexpected bath.
