Help please!! I relized I was leaking gear case oil between my prop. I have I did go tho the marine shop and purchased the two proper seals within the bearing case of the lower unit. I have tried like heck to remove these seals and have had no luck.
I figured must remove the bearing housing in order to do so. I relize there are four bolds inside the bearing housing that should be removed to take remove the bearing housing. No matter how hard I pull I cannot budge this housing.
1- is there an easier way to remove these old seals w/o removing the bearing housing? maybe 3-jaw pliers??
2- are there any tricks in removing this housing if it doed need to be removed?
3- I noticed that at the front of the bearing housing there are two tapped holes. Is there a special tool to leaver it out?
This seems to be a lot harder than it needs to be.....
