Hi all,
I'm glad I found this forum, as I'm sure I'll be perusing it frequently for info. I just bought an old P-14 fiberglass boat with a Johnson Super Sea Horse 40. The model number is RDS-22, serial 2043818. From what I've read here, it looks like it might be a 1960 or thereabouts.
She seems to run great, but I'm wondering what I ought to look for before putting too many hours on her. The points have been replaced recently. Does the cooling water flow out below the waterline? I can't see any obvious outlet for water. The engine doesn't run hot at all, as far as I can tell.
I guess the first step is to buy a manual, and perhaps replace the impeller. Any way to test or clean the carbs without removing them? The high speed and low speed mix adjustments I think are explained in another thread. I'm thinking I should figure those out, particularly the high speed, before running it too much. I imagine the manual would explain that as well.
Thanks for the info, and any other suggestions would be much appreciated.
Cheers.
Cheers.
