fishdog4449
- Jul 16, 2007
- 462
1980 Mercury 80 running very rough at idle. Timing is set at 4degrees at idle, carbs have been cleaned and new fuel lines. engine starts up fine, runs well at higher rpms. Idle mixture screws are set at 1-1/2 turns out. heres my question, when the mixtures screws are turned in to about 1 the engine smooths out but idles much faster; however i have been told this is way to lean. pulled plugs wires off one at a time, noticable drop in rpm for all except bottom cylinder which i could not check. any other culprit that would cause bad idle?
