rpm falls to 3000
boater51
engine runs above 5000 rpm for a while then drops to 3000.
what could be the problem??
90 omc jet powerhead
seems to be temp related
1994 90hp JEER
turbojet
ezeke
Re: rpm falls to 3000
Depends on the motor, but a lot of larger J/E motors have a feature called S.L.O.W. that cuts the engine back when it overheats.
Overheating could cause that symptom anyway as a cylinder begins to bind one or more pistons.
More information about recent work on the motor, model number etc. would be helpful.
ezeke
If it is an outboard jet drive, have you rebuilt the waterpump? Have you checked the thermostats?
tashasdaddy
sure sounds like it is getting warm and dropping a cylinder of two. tstats, coil or powerpack failing, 90hp has a pack for each side.
ezeke
That depends entirely on vintage TD. There are 90HP inboard turbojets from 1994 up that have one powerpack. and 90HP jet outboard all the way through with one powerpack. We need to know what the motor is.
ezeke
You don't have a waterpump, the jet impeller forces the water through. You should have a water filter, probably at the bottom of the engine compartment. Clean that out completely. It has an o-ring that you may have to replace. They usually have them in well stocked hardware stores that will fit if you take the unit with you.
You may have something stuck in the thermostat, but save that for last, because you have to pull the engine to work on it.
Water passages have two water deflectors on each bank of cylinders that can go bad and overheat one side or the other. Again, you need to pull the engine to work on those. The parts catalog for your setup are on-line at the BRP site:
One other thought is that the ignition coils need to be kept well grounded and they tend to corrode and lose contact where they are bolted to the cylinder heads.
http://epc.brp.com/default.aspx?brands=ej&lang=e
When you get to the first picklist, scroll to Turbojet.
You need the very best oil for that rig. I would run it on XD100 if it were mine. Don't use plugs any hotter that a QL77JC4.
