I have a Yamaha 225 EFI (year 2001) and a year ago I started having intermittent problems with the engine cutting out at WOT which would violently throw everyone forward every time it happened. The likely problem was a fuel restriction and the mechanic thought it was a sharp bend he discovered in our fuel line but even after repositioning the line, the problem persisted.
I searched this forum for an answer and found an engine with similar symptoms was fixed after discovering a clogged screen in bloat chamber & plugged filter going into pressure regulator. Another guy discovered the high pressure fuel pump filter screen at the bottom of the hp pump was plugged.
After the symptoms on my engine persisited (and got worse) I dragged the boat in for repair (yet again) and passed this info on to my mechanic but he found a different problem:
There are three fuel pumps on this engine and the middle pump had a 1 inch tear in the main diaphram preventing the pump from meeting the fuel demands of the engine at WOT which caused the engine to cut out. A simple fix ~ wish I new the answer a year ago. Hope this helps someone with the same problem.
