Hello All, My name is Joe and I am new here and need help..
I just bought an 85 Sea Ray
260 mercury
5.9 I believe
The issue is Forward and reverse work fine but I can not put in neutral from either.
The interrupter switch seems to work fine. I tested it and it kills when depressed. When I shift to reverse the ball rides up to kill the ignition.
My Question is- What are the causes for it not wanting to return to neutral?
If I play with it and/or shut the engine down the shifter works easily and goes into neutral with no problem. I understand there is no load on when I do this. Any suggestions or is the only diagnosis to cgange the drive cable?
260 mercury
5.9 I believe
