Re: Need info on adding a 2nd battery
**Edit** If you just worked on the charging system do you know what amperage it outputs?
Unless it's way up there your 70 hp rude isn't going to have enough juice in the charging system to use a combiner / isolator to keep 2 batteries charged. Your best bet would be to leave your system wired as is, and install the second battery as a backup. Always use battery #1 for starting and buy the biggest deep cycle you can get for battery #2.. Then use it when you're running the electronics and keep battery #1 reserved only for cranking.
The charging systems on outboards are designed to keep a battery topped off and trying to use them to bring one or more batteries back from a discharge state would take a very long time at WOT.
In this example battery #1 (Starting / Deep Cycle) is connected to position #1 on switch "A" (1/2/off/both) your starter/alternator/electronics are connected to the common post on switch "A". Battery #2 (A large deep cycle, group 27, 31 etc) is connected to position #2..
Normal operation, crank up the boat on battery #1 and drive to wherever you're going to swim/fish/anchor. Shut down the motor and switch over to battery #2 (previously charged before you left) and use it to run the radio, fish finder, trolling motor or whatever. If it goes dead you can always switch back to battery #1 to crank the engine.
Once you get back home put both batteries on a charger, you can get a marine charger that stays in the boat that will simplify things by allowing you to just plug it up and it will take care of the rest!
