Johnson 70 oiling up at low revs
athertop
Oiling up is just a guess - I recently fitted a 1980's Johnson 70 to my speedboat and took it for its first run yesterday. It runs like a dream, but the (Scottish) Loch we were on has some areas with speed restrictions and we noticed that after about 10-15 mins of running slowly, the engine starts to souund a bit rough - misfire would be a guess. Giving it quick rev clears this out and it runs fine again for a few minutes then reverts to this misfire again. I suggested oiling up, as when I rev it in this situation it gives off quite a lot of smoke, and I noticed that when we were driving it onto its trailor it had left quite a bit of oil in the surrounding water which left an oil line around the hull of the boat. At speed, the engine runs like a dream, and even running slowly for 10-15 mins runs like a dream at low revs - then it starts!
For further info - the fuel I used is a mixture of what has been lying in the (plastic) tank for 2 years (about 10 litres all pre-mixed 50:1, from when I last used the boat with the old engine). This was kept in clean conditions despite the duration. I added 20 litres to the tank before taking the boat out yesterday and 400ml of 2 stroke oil (50:1 at my estimate). The 2 stroke oil I bought yesterday was just moped oil, as I couldn't get outboard oil, wondered if that might make any difference?
Any advice would be appreciated.
Thanks, Paul
tashasdaddy
Re: Johnson 70 oiling up at low revs
it makes all the difference, the 2 year old gas, and moped oil. not a good combination. check what your plugs look like. if you can't afford outboard oil. don't go.
detourkid
Todays fuel suxs !
Shelf life of gas mixed with oil is about 4 months unless you add stablelizer then you get about 8 months.
straight gas has a shelf life of 6 months and about a 10 months with stablelizer.Get that gas out of there and if the fuel pump has a screen in it clean it tooo...You want any tcw-3 oil and that means to cool via water.. but that oil should work in a pinch...
athertop
Thanks for the advice. I'm gonna dump that gas and fill up with fresh and proper outboard 2-stroke oil. I also got new plugs today. I read in the forum here that if you gap the plugs a little wider that the spec - it said that for my engine specifically to gap them at 0.04" instead of 0.03" then that helps with oiling up at low revs. Any ideas if this is true?
tashasdaddy - it wasn't a case of not being able to afford proper oil - it was a case of using what was available at the time! I.e. what my local gas station had on the shelf.
Thanks,
Paul
