I bought a bottle of Spectrum Gel Coat Paste Repair (artic white)from a Sea Ray dealer to repair a couple of chips in the transom area and also attempted to fill in a chip on the upper driver's side near the gun whale. The chips on the transom filled in nicely and I sanded them down after letting them cure all night. With the chip on the side of the boat I made a slight groove with a can opener and then filled in with the gel/paste.When I did a little sanding with the 220 grit after applying the paste gel (after waiting 3 hours) I saw the black/darker color coming through.I switched to 300 and 400 grit wet sand but it didn't help.The patched area is really smooth but the white color seems to have disappeared and now I have a glassy black line about 5 inches long. The temps here in Wisconsin now are only the 50's with night's in the high 30"s. Is it temperature related or am I doing something else wrong? Is there a white expoxy paint I could use to paint the area? I have a few small stress cracks on the passenger side as well but am now reluctant to try to do any more until I get some advise.Any advice is appreciated.
Newbie to fiberglass repair.
