I aquired an old Clinton motor, has k500 on it. Had been sitting out for quite some time. It wouldnt pull either. When I took the spark plug off, there was water there. I know thats not a good sign. I emptied the water and flooded it with 2 cycle oil and sprayed the carb end with WD40. Than I was able to pull and actually feels like it has good compression. Than I took the carb apart, it was a bit nasty. Quite a bit of that white lumpy build up and somewhat corroded and the reed valve is corroded through too. I know that is not gonna work.
I called my local boat repair and asked if they had parts for a Clinton motor. They said "Clinton?" Than I went to a backwoods boat repair guy and he actually had one out back. Gave it to me for 10 bucks. This one was locked up solid but when I got it apart the carb was in alot better shape and identical to the other one. The only difference is the reed valve. The corroded one has a star burst shape to it and the one I just picked up has a pyramid shape design. I got all the carb parts soaking in gas and sea foam now.
My question is, will a different reed valve work?
