Re: Can i pull a 19ft Bayliner with a mini van?
I towed my 1985 19' Bayliner Capri (VP 4 cyl.) with a 1993 Voyager with
a 3.3L 6 cyliner engine for a couple of years. The engine and trans had
about 148,000 miles, and I had no problems with it whether I was towing
or not towing. I had installed a trans. cooler, lifetime spark plugs and a
K&N air filter. I also installed new sensatrac shocks on the rear.
The only issue with the combo in towing was that I couldn't run the A/C
when going up long hills. The powertrain needs to shift up to 3rd, and that
means slightly higher rpms. No problem for the engine without the A/C on.
The Town & Country mini-vans have the newer 3.3L engine, and that has
about 30 more hp than the older model. The 3.8L engines, in some of them,
have more hp and torque, but they run rough compared to the 3.3.
As far as the boat/mini-van combo goes, I would recommend them both
as favorable. I don't know about the bigger engine on the Bayliner, as I
have the VP4, and it is just right for what I want to do - mostly cruising.
If you want to read more about Bayliner feedback, go the Bayliner owner
forum where there is much to read about Bayliners. I like mine. Good luck!
