blue jon boat
- May 26, 2008
- 3
I have just purchased a 25 hp 1975 evinrude with electric start and a long shaft kit i took it out on the lake the other day and it was hard to start i tried choke no choke and any other combo finally it started it took it around the lake it ran good a full throttle and part throttle but it would not idle i have noticed the fuel tank seems to be pressurized but it is a single line system is that normal? or should it be vented for this motor
I also have a question about water flow there are two holes on the back below the cowl they seem to have exhaust with water blowing out and i don't see a tell-tale is a heavy mist or splatter normal out of these?
after i warmed it up and i killed it a few times it still seemed to be hard to get started and also i would like to know if it has a thermostat if so what temp does it open
Thanks for any help
Thanks for any help
