Re: 1973 50HP Evinrude no spark after moving
Well, I'm still at it. Motor started and ran. Changed both coils and have no spark now. Both old coils had cracks in them and one plug wire was so corroded it broke right out of the boot.
I looked at some old threads and found if I disconnected the red plug and jumped the starter, and still had no spark, that this test would take the ignition switch out of the picture. Well I did that and had no spark so I think the switch is not the problem so the next step is the Power Pack. Right?
I read in the manual about checking the coil connections at the power pack for voltage but I'm not sure what kind of meter to use. Will a regular VOM work? I don't want to burn my meter up. It said use a neon tester but I don't know what that is.
