Mercury 650 rectifier
andy77
hey guys.. I have a 74 650 outboard mercury that is not charging. It left me stranded at the lake at 3 in the morning. I guess that is when i decided that i should have paid for the full size paddle. I got a new marine battery, hooked it up and it had 12.6 volts. started engine and the voltage stayed the same 12.6 at both idle and higher rpms. I read a few forums on here and decided to look at the rectifier. Rectifier looked really good. no corrosion or anything. Removed it and too it to an electrictian i work with to shoot for omhs. He said it seemed ok. shot 400 ohms from stator post to power post both sides. I put the rectifier back on and started boat to check voltage at rectifer to make shure i didnt have a bad wire from rectifer on. It shot 12.6 volts at + post dc. Shot between both stator post and it read 14.2 ac. It seems to me the rectifer is messed up somewhere. I just want to make sure that it what it is. nothings worse than buying a part and it didnt fix anything. let me know what you think. thanks guys!
j_martin
Re: Mercury 650 rectifier
The ohms is insignificant, depends on the individual meter dealing with the nonlinear characteristics of a diode. Trick is, it should read one way, and not the other. And also to ground, but reversing the leads on the meter.
Electrician's half educated.
John
andy77
thats correct on the ohms. it would only read 1 way and not the other way. it was a digital fluke meter and it read 400 ohms from stator post to power on both post. it read only 200 ohms to ground. i dont know anything about ohms or much about a multimeter im just a diesel mech on locomotives. the final test of starting the motor and reading voltage tells me the rectifier cant be right.
Yachtzee
Which kind of rectifier. Plate, Thunderbolt ignition or diode?
Plate and thunderbolt seem to be full wave bride rectifiers, acutaly 4 diodes.
for the plate type The ratios should be 10 to 1 forward to reverse accross each pair of connections. The thunderboat style should read continutiy one way and open the other.
I have seen the rectifiers for sale for 50 bucks on the web,
I bought a 5 dollars bridge rectifier 25 amp 50 PIV from radio shack that has been working well. Make sure you have continuity from the + terminal on the rectifier to the battery. Not being hooked to a battery while the engine is running tends to fry the rectifier.
On another note I get about 45 volts AC on my 650 across the stator wires motor running at idle
chuckb
Yachtzee is correct. A $5 (even that's expensive) simple bridge rectifier will be a suitable replacement for the $50+ Merc part. You need to find the 2 wires from the flywheel alternator and hook them up to the two rectifier inputs marked with a sideways "S". The other two got to the positive and negative (normally engine ground).
