Carburetor Rebuild Question
sat1962
I just read in manual that u need to use 2 gaskets on carburetors between body and bowl .Was wondering if I used one what effect if any it would have on how engine runs engine is 70 hp johson 1988 thanks.Dont tell my wife but i just used one gasket haha
F_R
Re: Carburetor Rebuild Question
What manual was that? Well, there actually are two. The one around the outside of the bowl and the little one around the main nozzle in the center. Could this be what they meant?
samo_ott
I believe I have read that there's supposed to be 2 between the carb and the intake manifold and that the 2nd one is there as a heat insulation between the carb and the intake manifold although in all the kits I have there's only 1.
reeldutch
there is a litle gasket that go's around the emulsion tube, and there is the big gasket that go's around the float bowl.
probbebly you left the litle gasket out.
the engine will bog down as soon as you open it up.
good luck
