Re: 1989 125 Misses on Fwd only
Oh that's an easy one.....don't put it in forward!
LOL Just kidding!
Need to perform a few basic checks. Sounds like under a load it's breaking down. Need to figure out if it's an ignition or fuel problem but first you should check the compression. Should be around 120 LBS on all four cylinders. If that checks out OK a few things to check out. If you've never done this before, a manual will be very helpful.
Fuel:
1. Make sure carbs are clean and no gunk in carb float bowls. Float level needs to be verified. If any fuel leakage here, then you may need to re-build the carbs. Parts are relatively cheap, about $15 - $18. Pretty simple to do and manual shows how. Also fuel mixture screws should be adjuted correctly. About 1 1/4 to 1 1/2 turns out from lightly seated. NOTE: Does the primer bulb on your fuel line get hard when you pump it up? If not, this is an indication that the float level is set too high or a bad needle valve.
2. Look at the fuel inlet filter/screen on the fuel pump to see if any stuff has clogged it up. If so then there may be some trash in your tank. Inspect the fuel pump rubber diaphram. If it looks stiff or has any holes, it should be replaced. Another relatively cheap part $12.
