barroomhero
- Mar 30, 2005
- 52
Helping a friend rebuild a 1996 200hp Ocean Pro. All buttoned up and cranks but no start. Good secondary compression but no fuel at the plugs. I'm thinking loss of primary compression? If you put your hand against the carb and turn it over there is a lot of back pressure and then it spits fuel out the carb..... Pulled reeds out and found three reeds out of spec.... but would that cause a no start?
