Re: 2006 60hp EFI Fuel Pump Issues??
Yes, they replaced it under warranty. It appears that the second issues was a loose wire on the fuel pump. According to the dealer, the pin was not set correct...If it happens again, they stated that the only way to fix the issue would be to replace the wiring harness, which is a rather large process. If it comes down to that, I think that I will be asking for a new engine. They can replace the wiring harness on their own time. Summers are to short up here in Minnesota!
