fresh water cooling
bobrown
is it possable or advisable to add a fresh water cooling system to a older boat 1977 searay ford 351 never been in salt water but would like to use in gulf of mexico 4 months out of the year will be dry docked after each use
Don S
Re: fresh water cooling
Not recommended. Max "recommened" time before installing a FWC system is 125 hours or 1 year.
Get some Salt-Away and flush after each use, you should be fine.
bobrown
thxs don just purchased the boat my first dont know the hrs but everything seems to work great heard it was better to cool with freshwater
bobrown
don why so many replies to add freshwater system to boat regardless of age or hrs
Don S
I just gave you what the manufacturers recommend.
Pick the answer you want to hear, and go with it.
