drive shaft wear on 1996 150 ocean runner
reellife2614
while changing the water pump I located a wear ring on the drive shaft. The shaft moves around alot but the top bearing appears to be in good shape. I plan on replacing the bearijng anyway. Is the saft okay with a slight wear ring. Any advice is appreciated.
